V-Moda V80 mini review, a 200$ gem
oyster
Jaipur
Finally have my hands on the V-Moda v80. These are on ears & are quite small.
The build quality is almost reference for portables....lots of metal used.
Comfort- The pads are quite small, so its quite a challenge to get good fit.The pads warm up with usage .Overall comfort is average at least for me as i have large ears.
Sound quality-
Tracks & albums used-
Karsh Kale- Supernova, Cinema, Slither
Midival Punditz- Dark Escape(Closer OST), BBC radio one mix
Prem Joshua- Lahore Connection, Secret Place, Chandini Chowk
Karunesh- Call of the tribes, Om namo
She's All That- Jab Tac
Gareth Emery - Sound Of Garuda Chapter 2
Cafe Bombay- Upanishad, Pandas Dream
Matrix Revolutions OST- In My Head, Navras, Zion
Makis Ablianitis- Love Secret
Oliver Shanti- Dew Drops Of Light , Infinite Compassion etc
Buddha Bar- Indra Story, Indusufi, Karma Busta Rhythm
Rejuvenation Of Life- Planetory Healing
*As you would notice by the choice of tracks i do not listen anything even remotely related to Rock, Dub, Rap, Metal. So, i ahve now idea how the V80 would sound with such music.
These do not require much burn in. Overall sound is quite airy with fairly tight bass, forward mids & a very flat treble response with no spikes. These sound really beautiful with non bass heavy tracks.
The resolution & definition is significantly better than the Shure750DJ(another headphone i own). These are a step above the shures in terms of clarity & treble quality. Lower mids are more forward & airy although definition is better on shures. Upper mids are much better than shures(these have some spike in upper mids) with very nice texture, definition & clarity.
For bass the 750dj outdoes V80 by a wide margin. There is no competition.Not that V80 lack bass , in fact V80 has quite more bass quantity than 750DJ. It's the sub bass that is kinda ill defined. Depth, resolution, impact & extension are so much better on the shures. V80's mid bass isn't bad & remains quite textured & detailed at low volumes.It's also tiny bit better layered than the shures. But anything loud & the drivers run out of breath. But i strongly believe this is very much due to the fact that i've never been able to get a good fit with these & there is always a gap between the cups & my ears. With improper seal , bass is likely to suffer. But still i have a feeling , even with proper fit 750DJ's bass is hard to beat.
SS on V80 has really good depth for such small cups & is quite airy. Although LR separation is noticeably wider on 750DJ. Imaging is also bit better on the shures as they reproduce sound on a larger canvas mostly due to larger 50mm driver compared to 40mm of the V80.
The V80 do not require any amp. On the Cowon i9 these are plenty loud at 30 & are easily listenable at >16. However i do not like i9 a bit & all the listening was done through Touch 3g & Nokia X5 Line Out(HP out is crap as hell)
Conclusion - In the first place i wanted something with better refinement & the V80 are definitely a class above the shures in overall sound.
Oyster, had seen positive impressions of these hps on head fi. Have you heard the seen HD 25 ii which also falls in the same bracket?
Yes, I had auditioned HD-25 at apple store in Jaipur. Those were the adidas version with very loud coloured pads for my taste. Those blue pads look ugly.
The mid bass punch is way too much but its very likeable as the mid bass isnt as loose as the M80/V80. The layering & sub bass is definitely better on V80. Still for bass alone the shure 750dj just crushes both v80 & HD-25.
Mids are fine on HD-25 but not airy & thus sound congested. Although the upper mids have more aggression than V80 & thus better slam.
Treble is where the the HD25 lost my vote. I have a preference for flat treble even if its slightly muted. The HD25 has such a metallic tone, very sibilant. Better for screaming music but strictly prohibited for my taste of music :)
Also HD-25 are for ~15k in India , definitely not worth it. The drivers do not offer any better resolution & definition than 150$ solutions(say ATH M50)
