kirincorleone
Current Desktop Setup - 80% music & 20% gaming:
JBL Stage A130
Onkyo HT-S3800 6" passive 80w? sub (from HTiB)
Focusrite Scarlett Solo - DAC (replaced Topping E50 since I started learning electric guitar - I dont own a guitar amp)
Fosi Audio - BT30d Pro - Amp with passive sub outs
Meze 109 Pro Headphones - thinking of double amping using the headphone out from the scarlett into the schiit magni (i have) for that oomph its currently missing.
Space:
Room: ~250 sqft
Table + Chair Area: 6' x 5' = 30 sqft
Room Treatment: 0
Plans to treat it: None
Mounting Situation:
The a130's are mounted on the wall angled down at me but the angle is much less than whats required.
It is currently tilted down at 40 but it should be 50. So, the tweeter is missing my ears and pointing around 3ft behind me.
I feel the difference in quality if I stand up or move back my chair.
In order to fix this, I will have to ruin my wall, get it repaired and lower the height of the mounts by atleast 1 ft - which is a challenge as I can afford 6-8 inches. Also, the wall is a big project with civil work & paint. I would really want to avoid this.
Bias:
I am partial to Ribbon tweeters as I already own a HT setup with Emotiva T1+ & E1+ with E12 and I LOOVE IT.
I didnt like the Klipsch sound at all. I have demoed the 600? (I forget) for my HT and rejected them instantly.
I liked Dali Oberon's but found them a tad bright.
I like my JBL a130's but find them fatiguing.
Want more:
I am looking to upgrade now. I have gone through so many posts and shortlisted a couple. Issue is that the pricing & product availability in India is very different from western countries, thus the suggestions dont really match. Also, I am unable to demo the products in question.
Choices:
The choices are in order of my attraction towards them. Top mentioned is the one I like the most due to irrelevant biases.
Prices are in INR & USD.
My overall budget is 1Lac
Speakers:
Adam Audio T5V pair: ₹52800
Kali Audio LP6 v2 pair: ₹37980
Subs:
Adam Audio t10s: ₹70700
JBL LSR310s: ₹24783
Presonus Eris 10: ₹48990
KRK S10.4: ₹49400
Big Questions:
1. Is it worth upgrading a130's with t5v's or LP6's? Is the money spent even justifiable for the gains? The sub is a no brainer of course.
2. Should I also explore Passive Bookshelves? If so, what would be good upgrades over a130's? Also, I would want to change my amp then. Looking at Fosi ZA3.
Please help & suggest.
JBL Stage A130
Space:
Room: ~250 sqft
Room Treatment: 0
Mounting Situation:
Bias:
Want more:
Choices:
Speakers:
Subs:
JBL LSR310s: ₹24783
KRK S10.4: ₹49400
Big Questions:
