Dear Forum members,
I have a Velodyne woofer with following specification.
Woofer 8” forward firing (6.5” piston diameter)
Amplifier (Class D) 2000 watts Dynamic 1000 watts RMS Power
High Pass Crossover 80 Hz (6 dB/octave)
Low Pass Crossover 40 Hz-120 Hz 12 dB octave initial, 48 dB octave ultimate
Frequency Response 28-120 Hz (+/-3 dB)
Harmonic Distortion <5% (typical)
Magnet Structure 204 oz. (12.7 lbs)
Voice Coil 2.5” Dual Layer inner/outer wind
Inputs Line and Speaker Level
Outputs Line-level, 80 Hz up
Phase 0° or 180°
Video Shielded No
Dimensions (H/W/D) (inc. feet, grill and knobs) 10.063” x 10.375” x 12.75” (27 x 26 x 33 cm)
Cabinet Sealed enclosure
As I use it in my L shape room with sides dimension of 5m*4m*7m. The unit is unable to fill the room. Is it possible to change the 8” woofer driver with a 12” or 15” driver single / pair!
I want to use the entire electronics component with separate enclosure. Please let me know if it is possible at all? If so what drive I should you and where to source it.
The unit is intended to use for Music purpose only accompanying with a floor standing speaker having a 6.5” woofer & horn tweeter. (I want to avoid bellow 40 Hz sub woofer effect)
What is the disadvantage of using high efficiency driver like 12”/ 15”/ 18”over a specially designed sub woofer driver which normally has a low efficiency? (For Music purpose only)
Phase 0° or 180°
Video Shielded No
