ankitbhargava
Covid is giving all opportunities which weren't there in everyday busy life
I bought a UMIK 1 and read some basic stuff to venture into REW measurements.
The aim was to measure the accurate output and graphs from system and specially Subs, find out what Audessey MultEQ32 does to my system and if its worth, integrate the 2 differently capable subs in more jovial way, find acoustic issues with my Room and learn some technicalities (if the patience persists for a couple of months).
Please consider me as the learner at very basic stage as far as REW goes, so far I have only made improvements in my HT system relying on my ears.
I would like to open this thread to find out if I am approaching the measurements correctly and then to learn to analyse the result. Probably, make possible changes to system for any improvisations.
This is what I have done so far to take first measurement
1. Downloaded REW version for MacBook (which is still on Catalina)
2. Connected UMIK 1 with the supplied cable for input, connected HDMI cable from Laptop to AVR (aux1) for output
3. Did basic configuration, downloaded and added Calibration file
4. Set the level (which came out about -20.5db) on AVR to play 75db of pink noise using the signal generator (playing at -12.0 dbfs) + SPL meter on REW
5. Took a couple of measurements of Front Left, Front Right, Front L+R and sub woofers (separately and combined)
Please advise if I followed correct steps in measurement
I shall be posting the screenshot of graphs as well as the measurement file for anyone keen to help.
Thanks in advance
Thanks in advance
