VFM TV for guest bed room
cavallino
Delhi
What would you recommend? The idea is to put one TV in the guest bedroom where there is no cable/DTH. Would be used sparingly, but for watching xvids/x264. Will not have a home theater attached. I am thinking a 32 inch would suffice room is 12x12 sq. ft.
Thanks in advance
A Toshiba 32AV700E would suffice - you should be able to get it for 20K-21K. There is a Sharp and Panasonic 32" selling for similar prices...but I like the Toshiba for its piture quality. Check for yourself.
hi
Also some one from Mumbai is selling a brand new 32" full 1080p Sony. it will fit your bill perfectly and we can have both a happy buyer and seller. Pictures are attached too. So do have a look
Vinod
hi
Vinod
Can you give me the details or point me to the right link?
hi
Vinod
thanks for the info
but I am in Delhi:sad:
