Viewsonic HD MEDIA PLAYER - 1080p
Karanboochra
India
How is this player guys ?
Amazon.com: Viewsonic VMP70 1080p Full HD Digital Media Player: Electronics
Looks good, awesome reviews, DTS 5.1 CH possible , and it's got a free HDMI 1m cable too :P
Does anyone have this ? Is it worth it ? It's for 4k i guess..
A customer review -
Pros: Very pleased with this media player. This is the first device of it's kind that I have ever purchased and it made a great gift. Very simple to use, small and light so it should fit easily even in a cluttered entertainment center. 1080p MKV files look great and play perfectly smooth.
If you think about it, you've gone from standard definition TV to everything being Flat screen and High Def. Well, this is the new DVD/Bluray player. Instead of being bothered with discs, you can back up everything you own onto hard drives that can act like a shelf full of movies, and you'll never have to physically look for them ever again. Boom, they're all right there at your fingertips, a few clicks away.
Cons: There are not buttons on the device itself other than Power, so DO NOT lose the remote!
Other Thoughts: Well worth the money.
Choose WDTV or Xtreamer or Playon HD Mini instead of this .
because all above are well known product, If anything goes wrong fix will be easiest to avail (i,e flashing firmware/RMA etc etc), those are my point of view.....else u decide.
