Vinyl Record Cleaning - Kits Available?
sixstring
bangalore
Hey All
I've just acquired a bunch of Vinyl records, most of them pretty old.
Where can I find commercially available record cleaning kits in Bangalore/India?
Any other advice on cleaning my vinyl LPs would be appreciated.
Thanks!
Search for SpinClean disc washer system. I had used it for some vinyls and found it very effective and easy to use.
Don't bother...it's a waste of time and no fun at all...
Give them to me...and I'll give you MP3s of those albums :D
You can contact The Listening Room Bangalore for the Knosti cleaning kit. Available locally.
What a coincidence! I just read good stuff about this kit on a couple of forums just yesterday, and had dropped it into my wishlist. Good to know it is available in India!
You can get your vinyl care kit from New Gramophone House.
http://www.ngh.co.in/category/43-stylus-cartridges.aspx
They ship very promptly anywhere. The guy owning this old shop in delhi is Anuj. His no. is 09810955557.
Hope this helps.
:D:D & just in case you would like to avail the offer by FM soulforged, I am next in the queue!!:D:D (just joking)
Saket
INR 12,000/- for a cleaning kit from NGH!!! :mad:
Phew.....
Ive developed my own magic potion and method to clean my Vinyls which believe you me is very very effective. Plus it gives me that real feel of my passion when I hand clean then.
Hey All
Thanks!
You can contact Mr. Jochen at Bangalore as Reignofchaos suggested. I own the Knosti kit and it works pretty well and best part is it is available in India.
