sandeepgarg
On the deals of the week at ebay.in, the seller is offering this tv for 38,000/-. e-bay is also offering a 1 TB 2.5" WD HDD along with it. I think it will have dealer warranty (for whatever it is worth).
VIZIO XVT323SV 32-Inch Full HD 1080p LED LCD HDTV
Connections
HDMI (with HDCP): 4 (1 side)
Component: 1
Composite A/V: 1
RF: 1
PC input (RGB): 1
Ethernet: 1
SPDIF Digital Optical Output: 1
Stereo Audio Output: 1
USB: 3 (on the side)
Dimensions
TV with stand: 30.99" x 22.45" x 8.65" (WxHxD); 25.13 pounds
TV without stand: 30.99" x 20.78" x 2.0" (WxHxD); 22.60 pounds
What's in the Box
VIZIO XVT323SV RazorLED LCD HDTV, VIZIO VUR10 remote control (2 AA batteries included), detachable base and thumb screw, power cord, VIZIO cloth, safety strap, user manual, quick setup guide, registration card.
Amazingly slim at only 2".
Technical Specifications
Screen size: 32 inches
Tuner: ATSC/Clear QAM Tuner
Native Panel Resolution: 1920 x 1080 pixels
Computer Support: Supports 1080I(HDTV), 720P(HDTV), 480P(EDTV), 480I(SDTV)
Display Compatibility: 1080P(FHDTV)
Dynamic Contrast Ratio: 1,000,000:1
Brightness: 450 nits
Response Time: 5ms
Picture-in-Picture (PIP): Yes
Picture-outside-Picture (POP): Yes
Zero Bright Pixel Defect Guarantee: Yes
V-Chip: Yes
3D Comb Filter: Yes
3:2 or 2:2 Reverse Pull-down: Yes
ATSC with 8VSB and QAM demodulation: Yes
ATSC with MPEG-2 decoding: Yes
NTSC Video decoding via Video: Yes
Progressive Scan Video: Yes
Color Fine Tuning: Independent Red, Green and Blue
Universal Remote: VIZIO Bluetooth Remote Control with Qwerty Keyboard - VUR10
Panel Lamp Life (typical): 30,000 hours
Voltage Range: 100~240 Vac at 50/60 Hz
Power Consumption: 74W (AVG), < 1W standby
Wall mount hole pattern: VESA standard 100mm x 100mm
What say?
Connections
Component: 1
Composite A/V: 1
RF: 1
PC input (RGB): 1
Ethernet: 1
Dimensions
What's in the Box
Response Time: 5ms
V-Chip: Yes
3D Comb Filter: Yes
What say?
