harmandeep
Hello,
Can anyone please confirm if 43 or 50 or 55 or 65 inch model (Mi 4x or VU premium) is supporting 4K@60hz Chroma Subsampling 4:4:4 or not?
I am particularly interested in VU Premium 43.
I plan to use TV mostly as PC monitor for Coding and Work, so chroma subsampling is important.
Reason for 4K: More resolution v/s 2 * FHD Monitors.
Reason for 43 inch: 100% display Scaling at 4K
Reference: https://www.geeks3d.com/20141203/how-to-quickly-check-the-chroma-subsampling-used-with-your-4k-uhd-tv/
To test this, try to display the test image when connected to PC 4K@60hz to see whether 4:4:4 support is there or not
http://www.ozone3d.net/public/jegx/201412/chroma-subsampling-test-4k-tv.png
Thank you
Thank you
