Want stylus guared for shure m44-7
sunder
india
Hi friends, I need a stylus protective guard for the Shure M44-7 cartridge. If any one have, kindly let me get, it will be highly appreciated. Thank you.
-Sunder.
Hello Sunder - Your thread in the wanted section should take care of this. All the best.
Kartick
If one of us has a used/old/damaged stylus from an M44-7 lying around - he could use it. I would have sent him one if i hadn't thrown it away during a relocation last year - he's looking for something like that i guess. Shure won't sell the stylus guard alone
other alternative is to buy a new N44-7 and use the guard off that and keep the other stylus as a backup for when this one gets used. Its price is going to go up only so its a good investment if you listen a lot
Hello all,
Nice to be back! Joining the discussion, I see one N44-7Z retailing on Amazon India, priced at 3599/-
How is it different from the stock N44-7 stylus? Or is it the same?
Saket
The Shure dealer in Mumbai Mr. JD is selling the entire M44-7 cart (including stylus) for around Rs. 3,900 plus tax. I think, the tax is around 5.5%. Only stylus is available for Around 1,700.
I bought this stylus for about 1900 bucks about an year ago from ngh. So as of amazon pricing, it has almost doubled.
Stylus guard is not a critical part of your stylus hence you can even try the guard from other Shure stylii. Just ensure that it does not knock the stylus during application. If anyone has worn Shure stylii, they can probably part with the stylus guard. Just ensure that you re-calibrate your tonearm (VTF and anti-skate) after adding the stylus guard.
