What can i get in 30-35k
new mumbai
Which Lcd can i get between 30-35k....
I am seeing that brands like Mitashi, Lloyd and videocon are providing 40-42 inches lcd in that budget...
While sony, samsung and philips are providing only 32 inches in that budget!!!
So can u suggest me wether i should go for sony, lg's or normal brands like haeir, lloyd etc!!!
First decide which size you want to go for: 32" or 42" ?
If you want 32" , there's lot of option you can go through threads which have been already discussed in this forum.
And for 42" budget models you can refer to this thread http://www.hifivision.com/television/3156-economical-lcd-tvs-thread.html
From my point of view, you should refrain from temptation of a big screen LCD from the brands like Markson, moserbaer , moserbaer, Lloyd. Because these brands source their hardware from questionable Chinese manufactures and neither have exhaustive R&D department nor After sales service network.
You can check economical models from Toshiba and Sharp, they don't fall in that category but their service centre support is somewhat weak. Here is one from Toshiba http://www.futurebazaar.com/Product/Electronic+Deals/TVs/Toshiba+Regza+40AV700E+LCD+TV/2449994
For peace of mind, I advice you to go for 32" model from LG, Samsung, Sony if you can't stretch your budget for 42" LCD.
Hi Niraj, my friend you have a lot of options to choose from.
Its better to chose a good 32 than a normal 40/42 ones.
Go safely and go for Sony Bravia 32BX320 or samsung 32CA450E1M, both of them are excellent and you have options to have most supported formats in video from USB. In Bravia u will have additional FM in built.
Have a happy hunting !!!:yahoo:
