What is more preferred. Spades or banana plugs
Banana plugs. Or spades
  • Total voters
    16
I guess banana plugs are easier to manage. Once in a while, I have to clean the back side of the whole HT setup and I wish that the speakers had banana plugs instead. It is not as if I cannot change, but I am too lazy.
I was born with a Banana Plug and clearly I prefer it for regular duties :ohyeah:
Imagine looking down and finding that its mutated into a forked spade :eek: :D
Jokes aside spades for the speaker side and Banana for the amp side is what I would prefer.
You never gave the option 3 of neither/nothing ... usually its my answer to "does this dress look better on me darling?" and so its the same for my audiophilia :ohyeah:
-G0bble
For me
theres nothing like a good spade
WBT-USA
the WBT ones are excellent
the spade is a composite of 3 layers
this composite actually allows the spade to depress a bit when compressed ( i.e tightened against a terminal)
this in effect acts like a locking spring wiser
one of the best contacts i have seen
using a spade correctly keeps the Cu of the wires from getting into contact with the atmosphere
i personally feel this helps keeping the signal pure always
A teflon coated speaker wires termined by a wbt spade with heatshrink is my favorite
minimum contact of the speaker wire with atmosphere but max contact with the terminals
i vote spade
I use bare wire to connect. I have thought about going for banana plugs, but wasnt really sure how much I would have to spend to get ones that do not detract from the sonics.
Hi all,
Was using MX Banana's , but one of the screws lost its thread which made deterioration in sound in one of the channels. So tried bare wires and liked the SQ. May give a try to the WBT suggested by Magma in future.
N.Murali
-G0bble
Ha! Ha! I always love to read your posts.
But OP is asking what do you prefer! Spade or Banana!! :p
Spade for the rear sockets ... banana for the front ... :D
Actually I use bare copper coated with WBT 4% silver solder in practice. It becomes like a banana plug but without the springloading force, and I connect it like regular copper wire, dont insert it like a plug. You can imagine the rest ... ;)
--G0bble
doesnt matter, sonically they are all the same assuming decent material and build. no one can make out the difference by adding a hunk of copper.
I prefer spade for speakers and banana plug for amp. But I have not been able to source good spades in any shops in Kerala. Some one can help me get good spades because my speakers can be connected only with spades
For me
WBT-USA
But then, the cable is held by the two screws, so it might as well be bare wire held by the binding post screw?
I have banana plugs, crimped to the cables. Ten years later, I think I'd go for bare wire.
What matters? Enough metal, enough contact area, secure fastening.
Most speaker cables are probably way over-spec'd anyway. Apart from the fact that the insulation would probably break down, you could run an AC machine using mine, but does it make sense to use thick wires and end in a thin banana plug? That's why I'd go for bare wire --- even though I don't think it would really make a difference.
People like their cables to look good, and terminated cables are always more satisfying, even if they are out of sight. I agree that aesthetics are important, and would then choose machine-crimped spades, but only if they are the right size for the fitting.
Blue Jeans cables offer ultrasonic welded banana or spade terminated cables.
However, they themselves say that they recommend bare wire termination where feasible. Sometimes, a thick gauge wire won't even fit into an interconnect.
