Here's a stupid version of the answer till the knowledgeable ones show up:
When you connect an audio source to a pre or a pre to an amp, the impedance of the 1st stage (o/p impedance) should be considerably lesser (by atleast 10 times as per an old jungle saying ) than the impedance of the 2nd stage (i/p impedance). Using a buffer between stages 1 and 2 helps you achieve this without increasing the gain of the signal. A tube buffer is just a buffer that use tubes to get the job done.
However, a tube buffer these days is also (mainly) used by people to infuse 'tube' flavor to a solid-state source, something akin to artificial sweeteners.
...What is this 'tube' flavor ? What's it adding to a solid-state source? and what is actually solid state source? what's artificial sweeteners ?...
