Amplifiers don't have support for Bluetooth and legacy receivers don't have support for a aptx bluetooth. I found this aptx bluetooth receiver in amazon. This comes handy for those cases. Any one has experienced this or any such device?
I Understood that. Does aptx really improves or not? Some one who has tried can explain experience.Bluetooth connection is just a convenient compromise. Its no way near the direct connection when it comes to sound.
Aptx improves connection quality and speed.I Understood that. Does aptx really improves or not? Some one who has tried can explain experience.
This is the same product which I have quoted in my post and we are discussing. Thanks for your input.One on amazon.in,
Signature acoustics, supports aptx hd.
Also has optical out, which can be connected to optical in of a dac.
Its a low latency BT. Very good quality for the price.
It can act as a receiver as well as transmitter
I am using it in my stereo setup.This is the same product which I have quoted in my post and we are discussing. Thanks for your input.
Thanks. What is your source? Smartphone or any other device?I am using it in my stereo setup.
Noticeable difference between aptx and aptx hd sound quality
I have seen your prior posts - based on what you want to accomplish, you'd be much better served with getting an appropriate streaming receiver like the CCA or airport express which will be only marginally more expensive than a BT receiver - The only problem being both are not manufactured anymoreAmplifiers don't have support for Bluetooth and legacy receivers don't have support for a aptx bluetooth. I found this aptx bluetooth receiver in amazon. This comes handy for those cases. Any one has experienced this or any such device?
I already have CCA which I use a lot. For sometimes local files played via Bluetooth is preferred in my use case. So end up buying Signature acoustics aptx hd Bluetooth.I have seen your prior posts - based on what you want to accomplish, you'd be much better served with getting an appropriate streaming receiver like the CCA or airport express which will be only marginally more expensive than a BT receiver - The only problem being both are not manufactured anymore
ebay.com has plenty of options although a search on olx/quikr may also help locate something locally
If you are OK with spending a bit more, I cannot recommend the Paradigm PW Link enough
BT will turn out to be a disappointment given the loss in SQ (which I can still live with) and stream drops - unless you are sitting close to the receiver (and that I don't think anyone can live with)
I suggest you look into ifi Zen blue Bluetooth receiver. I am using it with my lg v30 phone and it can stream almost all the Bluetooth codecs including aptx and ldac. I am using it to stream from my mobile to pm6006 through schit modi 3 DAC. It's got very good reviews and I am satisfied with it.BT unit of Signature acoustics, aptx hd is still going strong. Identified by hosts as Phoenix.
Very useful product.
