which is better....denon1912 or pioneer 1121
Atul9768
Ghatkopar
ive enclosed two images
view1 is viewing on tv using 5.1
view 2 is for projector using 5.1 but the direction is perpendicular and i need to probably shift the speakers manually. such a situation is very rare , only if many people are viewing.
im worried bout the sound quality change when im viewing on projector.
will it affect ?
any particular AVR i need to buy .
ive zeroed on to denon1912 and Pioneer 1121.
ive considered DLNA.........Pre out ......ZONE 2 ...3D ....
how will multi zone help here in my case.
no just wanna know whts the price you are getting for these 2 in your city, since prices have risen a bit these days
Why not just go with view 2 and put the pull-down screen in-front of the lcd tv.
If that's not an option - then Sherwood R-972 receiver can let you identify any speaker as the center and rotate the sound field with it. Although, that receiver had lots of issues in the past. Hopefully, the latest firmware fixed it.
