Which is the best earphone in 3K?
vix41085
india
plz someone suggest me best earphone for my sansa clip+? range 3-4k. and someone tell where can i find brainwavz m2 online in india?
and any other online in india?
hey even i have a sansa clip+ . You can pair it with the following earphones around 3-4k
1.brainwaves m2 - Rs 3800 from pristinenote.com ( i bought my sansa from there)
2.'jays a-jays three' -Rs 3000 from letsbuy (will be around 2500 after discount coupon)
3.etymotic from ebay
read about their own sound-signatures on headfi or headphone review websites
M2 is ~ 4K now? :eek:. That would take it out of VFM category then. At that price for M2, I'd rather look at $100-130 deals from head-fi (used). A couple of grand and then some for sure, but then we could be getting into a far better SQ domain. If local warranty is a must, then go with M2 from PN. Otherwise, they could be had for cheaper directly from MP4Nation itself.
Xears have far more value at 38 EUR shipped after the coupon then. They may not have the best build quality, but they sound very nice. Look at Ultraphile, XE200 and TDIII v2/N3i (depends heavily on your preference in sound).
i's say if its for a pod! go for an sound magic ear phones into a fiio ipod headphone amp and its the best sounding thing you will get....
I have heard Sennheiser CX 300 II which my friend owns. I used it with Sandisk Clip. The sound is very good , rather excellent I should say. The bass is tight and mids are smooth and best thing is highs, they sound like floating in the air.
Soundstage is ample. I think this is one of the best IEMs in this range.
Price around 2,400/- .
Here is a link for review Sennheiser CX300 II review | from TechRadar's expert reviews of Headphones
Hope this will help
Rupam, when you say the cx 300 II is the best in this range, what other iems are you comparing it to?
But, Yuin PK3 is an ear bud which would offer no isolation. I thought he was asking about IEMs mainly going by the mention of M2 in his query.
Even in that case, I'd recommend Blox M2C if it gets back in stock (http://www.bloxearphone.com/). It is right now said to be the best ear bud under $50. Am likely to get one later on.
Well he was not specific, so mentioned earbuds
*Sent from an Android device*
