i have been facing issues with my bsnl fiber bundled ont cum router where some devices get kicked out of wifi or there would be severe packet loss or latency increase.If i connect via ethernet then its fine.Added to this is th inavailibility of wifi range in the adjacent room.i was earlier using extender but that pulls down the speed from 60 to 10.
Hence i thought of buying mesh router.My options are
1.netgear orbi RK59(tri band)-20k
2.motorola MH-7022(tri band)-14k
i read reviews of both but i trust the wisdom of users here and hence what would you suggest
Sandeep
Sandeep
