Hi all,
I am looking for a receiver that allows me to:
Above functionality is a must. I will primarily use it for music in bedroom with KEF Q300 and don't care much for the home theater quality.
Any suggestions on what to get? Budget I can go to 1L.
Based on my research I could find 2 solutions:
Will the sound difference be huge between these given that my speakers are decent but not exactly top end? Should I go with Denon?
I have ruled out Marantz as they don't support Airplay in second zone, while Cambridge Audio doesn't have anything suitable.
Thanks!
- Play 5.1 in my bedroom
- Play stereo in my bathroom as second zone independently as well as simultaneously
- Play music from Macbook
- Control the receiver from bathroom (there is wall between bathroom and amp)
- Get NAD T748 which has high reputation for sound quality. Connect Apple TV to DAC and DAC to NAD. Why the DAC? Because the NAD can't play digital input from Apple TV in the second zone, only analog is supported in second zone. I already have Apple TV and DAC so these won't cost me but there will be extra cable clutter :sad:
- Get something like Denon AVR-X1100W which has built-in Airplay and supports it for both zones. It also has iPhone remote to control receiver from bathroom hyeah:
Thanks!
