Mayank Shah
Hello, please suggest an optical cable, 1.5 meters. Prefered budget is 3k but max is 5k. This cable will be used between streamer and external DAC. Thanks, stay safe.
Thanks. No idea where to get Lifatec. Does the length, twists, turns on an optical cable affect the signal/SQ in any way?
Length usually does not matter much for under 5m.Thanks. No idea where to get Lifatec. Does the length, twists, turns on an optical cable affect the signal/SQ in any way?
+1. I do recommend it.Try lifatec
Curious to know about your DSD transport. Please share us some knowledgeit does DSD64 in my setup
It was with Cxn v2 Streamer & Lifatec cable , But currently With macbook mini optical out & MX Optical (though it sounds very good) , It doesn't do Dsd. The Problem is both Transport and DAC should be able to do that.Curious to know about your DSD transport. Please share us some knowledge
