Which Power Amp
I've not auditioned emotiva personally, but i've heard quite a few accolades about emotiva, will be helpful if you could share your usage and details like which speakers are you planning to pair with, pre-amp etc.
Mike,
Thanks for the Reply
Purpose is pure High Quality Music.
Currently I have a Denon AVR 3313
I am pairing with KEF Q900 and planning to buy a Emotiva Pre-Amp
why are you targetting 5 ch amp then if want pure music.
try either
DAC+Passive pre amp+2 ch power amp
or
denon avr pre out+2 ch power amp
off course 1st option is better but costlier
emotivas are highly acclaimed no doubt
you can also try indian acoustic portrait brand amp...they are also very very good for the money..expecially for 2 ch pure music..
Prosenjit,
The reason for me to go for a 5 channel is that, it can be leveraged in future for other speakers as well. Also, the price difference between the 2 channel and the 5 channel is just 100 dollars.
I assume, going for a 5 channel will NOT affect my stereo listening experience. or will it ?? As of now, only two channels will be connected to the front left and right speakers and the rest will not be used. But can be put to use in future.
I guess, and I assume I am right. If I am wrong pls. let me know. :)
try either
or
Prosenjit,
How do I know if a Pre-Amp is a Passive Pre-Amp ?
If I am going by the choice 1, how will my complete connection look like along with Denon AVR 3313( which has a pre-out )
I am unclear about the Pre-Amp part.
By the way, how is the below Pre-Amp ? is this a passive one. ???
PRE-1 Preamplifier | Sherbourn Technologies
you dont need any pre amp now passive or not passive..
just connect denon pre outs into emotiva power amp RCA ins
i mentioned dac+ pre qamp+power amp is a dedicated music set up..
okay..great for a future 6 ch movie set up and present 2 ch music set up..yes then go ahed for emotiva xpa 5 or upa 5...
you can concta avenue sound..they take emotiva orders..or you can directly import..
no its(u mentioned) a active pre amp..
passive pre amp does not need any power source
An AVR can never compete with a pure 2 ch amp. Otherwise it wouldn't be a $100 affair.
An power is highly dependent on the speakers it is going to drive. Let us know about your speakers before we can take it any further.
Prosenjit,
Thanks for the explanation..
Actually instead of Emotiva, I have zeroed in on Sherbourn,as I felt Sherbourn is a kind of Premium Quality of Emotiva.
PA 5-200 5-Channel Amplifier | Sherbourn Technologies
Why Emotiva, why not Sherbourn. :)
Whats your thought on Sherbourn. and any idea how long they will take to deliver.
I have KEFQ500 for now, but will go for KEF Q900 very soon once Power Amp arrives...
Once heard Kef300 with quad 306 and passive pre in an audition at ProFx and wasn't very impressed. Can't say which was weaker. Liked the quad b&w combo so opted for that later on.
Have you auditioned KEF with any other amp? I would suggest you to audition before considering any amp. Amp like any other component in the chain can make night and day difference.
These are not the same thing. I am quoting and adding from another thread which put it simply:
Bi-amping requires a speaker with two sets of speaker terminals, one for high, the other for lows. Each terminal set is run to a separate power amp. If you do not use a powered crossover before the power amps, it's called "passive" biamping and all amps should have the same gain. However as many times one does this with the goal of eliminating the negative effects of a passive crossover, the purpose may be defeated.
The disadvantage of bi-amping is mainly cost because you need more amps and an electronic crossover. You have to either have speakers that are made to be bi-amped or you must modify them (remove the crossover and add a second set of speaker terminals). And there is a lot of work to set up the system to make it play correctly. Bi-amping is not plug and play. You need to set the crossover frequency, set the gain for each speaker's driver, and set the time alignment for each driver, too. Otherwise, just don't do it.
Bridging is when two channels of a stereo amp that's made to allow for bridging are combined into one more powerful channel. The down side is that this bridged amp "sees" the speaker load as one half it's rated nominal impedance so it works harder. Another thing to keep in mind is that not all stereo amps are made to be bridged. You can blow your amps etc. if this is not carefully managed.
Honestly, in your case, I would not recommend either bridging or bi-amping. Often you are much better off with a good new 2 channel amp with more power (if that is what you need).
Hope this helps.
The above is relevant only if it is active bi-amping isn't it?
