sujithblaze
Own a pair of pioneer Andrew Jones floorstanding speakers and the center channel, was considering to upgrade them, i am looking for ur advice on which speakers to upgrade to budget would be 75k max
You can consider JBL stage series as an upgrade..I will be pairing them with a denon x2600h
I have moved to QA 3050i and very happyOwn a pair of pioneer Andrew Jones floorstanding speakers and the center channel, was considering to upgrade them, i am looking for ur advice on which speakers to upgrade to budget would be 75k max
Did u upgrade from AJ's? Which avr did u pair it with?I have moved to QA 350i and very happy
If you have a Subwoofer then you can opt for bookshelves also..I have very limited options to audition speakers thats the primary reason for ur expert suggestions, like i mentioned also looking into bi ampable speakers so that i can utilize my 2 channels lying around unused, and i want to feel significant difference from my current AJ's, so fm's please guide me, many of u have the luxury of auditioning different speakers while i dont have it. Also 75k would be the max cant go over that unfortunately
Yes, FS52, it's been hooked to AVR (Marantz 5012) and Yamaha IA (RN-602).Did u upgrade from AJ's? Which avr did u pair it with?
How do u find the q acoustics,did u compare the 3050 with other speakers and what made u choose the 3050Yes, FS52, it's been hooked to AVR (Marantz 5012) and Yamaha IA (RN-602).
Didn't get you, could you please elaborate on it, i thought the q acoustics nd dalis were superior to my pioneerswait until the elevator debut reference is available. Everything mentioned here is technically inferior to your pioneers. Subjectively they can sound better, if a reference sound is not your target.
Actually I was looking for change, fs52 wasn’t bad though. 3050i (innovation) is enhanced version of QA 3050fs speakers, it’s very balanced, excellent tonal and high sensitivity that match with any high end amplifier ranging 30w -100w. I didn’t regret after switched to QA 3050i.How do u find the q acoustics,did u compare the 3050 with other speakers and what made u choose the 3050
Ooh okay, so you think upgrading from my Aj's to them wont make any differenceThere are no measurement available for most of the speakers avaialable here other than subjective reviews which has too many variables from the mood / health of the reviewer at the time of review to the non standard equipments / rooms it’s reviewed with. So, all those reviews are good at the best as some stories without no proper back up to the claims. Can be paid reviews too.
