rainbowsong2000
I had Dual BIC F12 and sold off recently, now I am in search of getting a new Subwoofer (Later will add one more). This is for Dedicated HT room with the
size of 18' L X 9.5' WX10' H.
My Current gears are Denon AVR 4500H > Parasound 5125 (5 Channel Amp)> SVS Prime Tower, Prime Center, Prime Bookshelf as 5-bed channels and Polk in ceilings as Atmos.
Since I have all SVS speakers is it good to go for SVS Subwoofers? If yes which one PB1000 or PB2000?
I have auditioned PB12 in one of our FM home which is good, guess the PB2000 will sounds the same and auditioned XTZ 12.17 which has a lot of settings to play around to get desired results.
Also, enquired about Rythmik FVX12, which is costing just 10 k more than PB2000. A lot of reviews are recommending Rythmik and it is equivalent to PB3000
Please suggest.
Please suggest.
