which tv to buy?
god2013
India
I am in willing to buy a led tv(no plasma) , my budget is about 40k.
I have shortlisted
samsung 32f5100
samsung 32f5500
samsung 32f6100
which of the tv's are more durable, long lasting and have better pq and aq.
THANKS
I have shortlisted
samsung 32f5100
samsung 32f5500
samsung 32f6100
Why are you not looking for Plasma..any reason? You can get a 43inch Plasma with very good PQ within your range.
THANKS
No one can guarantee longevity of any electronic item but SAMSUNG is a recognized brand and its products are known to last more but please remember to take an extended AMC/Warranty with the purchase.
Out of the above 3 choices...the last one is 3D and the panel refresh rate is 120Hz which is good. My choice is SAMSUNG 32F6100
samsung 43F4900 will blow away all of the above 32inches LED tv's for the same price!!!
I have a bright-lit environment, that is why i am looking for led. BTW does samsung honour warranty incase of panel failure during extended warranty period.
go for samsung 32eh5000....it has got fantastic reviews and is the best budget led model of samsung and is priced at just Rs35000...take a demo and check it for yourself....
Hello,
I would suggest you to have samsung 32f6100. The problem is this it's price increased by 2k so...:indifferent14:
@Swarna Surjya and @webmaster1, have you seen the real demo of 32F6100 model in showrooms and recommending me to go for the same or are you comparing the specs only with my other shortlisted models and recommending 32F6100.
I have seen this model in person while comparing with SONY W650A and found performance of this model quite satisfactory as expected from a budget LED. Though the SONY was exceptional in 2D, F6100 was a 3D and the 2D PQ and black levels are good enough. It is not possible to view each and every model in the showroom with the same feed and same type of programming say Sports, Movies, Soaps etc. due to showroom model limitations. Not all pieces are available at the dealers for demo. Even you can come across this situation sometime. If you are not restricting yourself to these few set I would suggest you to take a look at some other options like SONY W650/W674, Samsung f6200/f6400. The 39inch Series 5 Samsung is also a good option but it lacks basic connectivity options like audio out.
Never go by what the Forum says only...here the member express their personal opinion and experience.
The golden rule is - 'Trust your eyes' and compare different models side by side with different programming types both in HD/SD.
Can i buy the extended warranty of samsung tv within 1 year from the date of purchase of tv or should i buy the extended warranty on the same day of purchase of tv.
It depends. Some dealers would give on the same day, some give option of buying it before the first year ends. You can check with the dealer.
