Donivlapog
Less than 50k?
pixels | 89,70,240 |
frames | 30 |
MBPS speed Required | 269 |
Netflix recommends | 25 mbps |
Internet and its cost is still manageable but you can't get over the compression from Netflix, 4Ks are being streamed at max 15 Mbps. Even if you have 250 Mbps stable connection .. its of no useThere is not much 4k Content yet (and bandwidths squeeze them) for example a true 4k is like below
pixels 89,70,240 frames 30 MBPS speed Required 269 Netflix recommends 25 mbps
Which means that Netflix itself is possibly using a lot of compression to transmit real 4k. (so is that really 4k?) so all said, i think we should be good with 2K displays for internet usage till internet becomes faster and cheaper.
There is a ton of 4k content available everywhere. Every movie is available in 4k now.Which means that Netflix itself is possibly using a lot of compression to transmit real 4k. (so is that really 4k?) so all said, i think we should be good with 2K displays for internet usage till internet becomes faster and cheaper.
