wireless headphones
hseplak
I am looking for a good quality wireless headphones to be used with my audio/video equipment. I want it wireless because i want to move around my house room to room listening to music doing my other work,it should work in other rooms also while plugged in to the system. I once had philips infrared headphones but for that one had to sit in the same room where the system was,also they had to be fitted with two small AAA batteries either side which used to get exhausted pretty soon, so can someone suggest me good ones?
there are few threads for the same topic. i would request you to search for them.
also there is a group buy for AKG headphone.. the wireless headphone is good as reported by the members.. you can have a look in group buy section.
Which good bluetooth headphones and where to get them in mumbai?or RF headphones? and for what price?
where in mumbai can i get Sennheiser-RS120-Wireless-Headphones?
I do not know the availability in India, but I got it from Amazon via Shop and Ship (Aramex) total was 19.5K. But the performance is amazing, we can feel the music, you can even walk through to another room without outage as its RF. Very satisfied with the purchase.
Sennheiser headphones wireless RS 120 and other higher models are available on eBay. I think the price for Sennheiser RS110 starts from 4K or so. The RS 110 works on RF so there will be no problem with range..... and I think it is rechargeable.
As far as bluetoth id concerned, as per my experience, the range is very poor. I am currently using Motorola bluetooth headphones. The sound quality is relatively good but the headphones are pretty uncomfortable.
Hi manish26264 DID u say RS 120 were at 19 and half thousand {nineteen thousand five hundred} ???? i am really shocked for headphones,my budget was around at the maxx i can stretch five thousand can you suggest me good wireless headphones for that budget.
THANKS ONCE AGAIN.
THANKS ONCE AGAIN.
Yes its 19 and half thousand.
THANKS ONCE AGAIN.
Check in the Group buy section for AKG wireless headphones which are at 4k I think. They offer uhf wireless which gives a good range.
Hi, Where in mumbai can i find sennheiser wireless rf headphones, and which among sennheiser is the best and cheapest,as my budget is around five thousand rupees.
Sennheiser Rs110 Wireless Headphone is the cheapest costing around Rs. 4200.
Check Sennheiserindia website for MUmbai dealers.
I finally got my sennhiesser wireless headphones,RS 120 at 5k + ,they produce very good sound ,good for listening to tv and stereo music,good they come with rechargeable batteries and have nice range too. Thanks to every forum members who hepled me select the headphones.
