Hi friends,
i was looking out for audio rack. but it seems like the cost of ready-made racks is very high and they are as such not made in India.
I was thinking if possible to build a wooden rack with three shelves, at home. The idea is something like this. Also pics for diagram attached.
Number of shelves = 3
4 strong pillars made of teak wood. Pillar size would be 1.5 inch X 1.5 inch thickness.
The shelves would be of ply of thickness 18mm. Or i have heard that MDF is also used for racks. I would prefer wooden shelves but not sure if they are available in the size required.
Instead of putting sunmica/laminate on each shelf, i think a wooden feel is better for look and from audio perspective aswell. So thinking each ply is covered with vineer sheet on all sides. After that i can do some polish on each of the shelves to give the wooden look and feel.
The pillars would be attached from the left side and the right side to the shelves. That would free up the in-between area of shelf for complete use.
(see diagram attached)
any suggestions welcome. the above is just a thought so not sure if it would ever materialize. either i diy at home or explain to a carpenter.
regards,
amit11.
regards,
amit11.
