XT 50 Potential Buyers--See this
lcdfreak
India
Issue Details with images: Details with images are produced below:
1. Green-Pink Vertical Lines : The green-pink lines are visible all across the panel. I have clicked images for your ready reference.
In the suggested case, I am experiencing multiple vertical & horizontal lines. Historically, Panasonic has replaced sets even if users experienced even single green line.
http://img155.imageshack.us/img155/6650/photo0422b.jpg
http://img560.imageshack.us/img560/1438/photo0413r.jpg ( USB Mode)
http://img189.imageshack.us/img189/1340/photo0425b.jpg ( USB Mode)
2. Uneven Brightness : Screen has uneven brightness, which is reflected clearly by attached pictures. Pictures are taken in an absolute dark room, with no ambiance light.
http://img842.imageshack.us/img842/3176/photo0379e.jpg
http://img850.imageshack.us/img850/2799/indoor2.jpg
http://img839.imageshack.us/img839/5091/photo0377o.jpg
3. Cannot display BLACK: Possibly related to above brightness
I used a black slide for display. Please see the result. My acer notebook with far cheaper screen showed it as dark black.
http://img215.imageshack.us/img215/7362/blackscreen2.jpg
@lcdfreak..
Dude its defective.. I asked you to call panasonic, did you?
Or is it a scam?? 42" 3D plasma + 3D glasses + HT for 48k, I mean, how?
@lcdfreak..
I have called Panasonic per your inputs...Thanks for sharing your observations :-)
Also, above deal was offered by many others as well...
As till 2-3 weeks back there was no instruction from company on how many glasses come with 42 XT 50...I had seen the letter which later clarified 1 with 42 & 2 with 50....
Also, 47+HT+1 3D glass is still on offer@Same shop or others...
Panasonic guys are visiting on Saturday.....
Also, i have opened this thread as I could see vertical lines on pics of some other fellow as well..Thought that others should know this clearly and get saved, in case this is a common defect across X or XT series..
30-40..hours at best
Your tv is still in the break in stage. I suggest you to use break in slides. The issue might be a result of an uneven break it. Your phosphors are still maturing so maybe it'll be ok after 100 + hours. However, you should get it checked anyway :)
Also try disabling all types of software enhancements in the settings.
I visited a Pana shop and when I closely watched Green & Pink lines were also on Display piece, in USB mode at least....I checked ST30 also had it however relatively lighter in shade....
Lines are prominent when I am using Break in slides ...Problem is engineers from companies hardly know anything. My Sony LCD had issues and 3rd guy agreed this is a major problem and recalled the LCD.
I could not check the uneven brightness thing given the showroom conditions of using too much bright light....!!
Thanks Buddy. I am using slides.However, its is just for 30% duration.
I am using TV and USB mostly. I am using zoom 3 and settings are:
Contrast: 25
Brightness: -20
Color:25
Sharpness: 25
All other controls are set to off part from intelligent frame creator.
These lines are more clearly visible when I am using break-in slides..
Are these lines visible from normal viewing distance (>5 feet) while watching content from dth or something?
Final Verdict - Engineer Visit & comparison with other X50
Engineer visited today and must say what a humble man.
He shared the images through service menu and said those lines are normal.
Also, I had visited pana shop and found those lines on XT50.
He also added, problem is when thick line appear. He further added, if there was a problem, service menu would throw an error.
Finally, he suggested no need to worry, if there is a problem, we always replace the complete set.
Guess, it is common across all sets.
Blasto: Bro whats your take? I rely usually on your inputs. :-))
Not sure if it has anything to do with this. Anyways, this is straight from the horses mouth
Q11. I have noticed over-emphasized green tones in the picture. Can it be turned off?
Answer:
Panasonic plasma TVs have a special circuitry called Color Management. This feature automatically enhances green and blue to achieve a more vivid color reproduction, especially for outdoor scenes. This feature is set On by default, however, it can be turned off within the menu's Picture settings.
VIERA Global FAQs | TV | Digital AV | Consumer Products | Support | Panasonic Global
Re: Final Verdict - Engineer Visit & comparison with other X50
Did you show him the uneven brightness atall?? Thats the problem we were talking about?
My 50VT20 bought last year has developed a green line on the right hand side of the screen few inches from the bezel from top to middle of the screen....I have logged a call with service centre ...............waiting for the engineer to call me .....been 3 days.......will let you know of my experience on the green line ( hope it dosent turn out The Green mile for my set)
Nishab are they gonna replace the panel...is it written in warranty that dead pixel not covered under warranty..on what basis pana guys are saying that?
