Yamaha 298 + Jamo 210
she_abs
Goregaon, Mumbai
Hello members
I recently (on 15th aug) bought
Yamaha 298 : 33k - 5k = 28k
5k less as i replaced the woofer came in the box with Jamo 210 which cost 18k.
Not tried video yet but quiet happy with the audio quality.
Hope this info will help members.
where did you buy?
i was planning for yamaha yht299 . any draw back's of the system? i have wharfadale 9.5.. was planning to connect them with 299..
Congrats she_abs
I never thought a package like that can be broken that way.
Now you enjoy!
A friend picked up one from Profx but was not given a choice to exchange the sub. paid Rs 36k for 5.1 with Yamaha avr. Music Sounded good
Hi there
Today i tried to play Iron Man dvd (piarated) through my Pioneer DV-610 AV dvd player which is connected to avr (Yamaha HTR 3065)with coaxial audio out. Video is connected through PbPrY format as i am using crt tv.
The problem is i am not able to get 5.1 channel sound.
Can any1 will able to help me with settings online that will be great.
Any mumbai guys willing to drop in & help in connecting it properly will be great.
Beer is on house for them.
Thanks in advance
Anil
Hi there
Thanks in advance
Anil
Are you sure that the DVD has the 5.1 channel sound as you said that its a pirated one. Most of the pirated DVDs have multiple movies copied and hence to save the space normally its a 2.0 and may be rarely 2.1 channels. Try with the original DVD and I am sure you will get the 5.1 channel output.
Hi She_abs
As mentioned by others Pirated Discs mostly do not have 5.1 or DTS recording....infact the sound is so blurred up that I hate even watching beyond 5 mins....you should get a Pioneer Blu Ray player BDP 150 which is a 3D player....it has USB slots where you can connect pen drives or 1 TB portable hard disks...I download all my movies from the net which are Original 5.1 or DTS rips. When I play them, immediately DTS or 5.1 displays on my Marantz AVR and I get the subtitle and audio language options too....
You can ask some of your friends or if you have any other original DVD just to check if the coaxle is working fine...else...read the operations manual and check if everything is done as recommended. It may be wise to get a good coaxle cable..
Hope this helps
Hi She_abs
Hope this helps
you download DTS rips or DTS HD-MA / Dolby True HD rips??
