Yamaha rx v473
cw45
Ca.
Don’t seem to be getting sound from rear surround speakers. Any setting suggestions?
Can you tell us the Audio source? Like is it played direct from Bluray or is it signal from your Cable Set top box?
Make sure you are indeed using a surround sound encoded source (dolby-based or DTS-based), else most probably the source contains stereo audio and you wont be hearing with surround speakers.
