Zener Diodes
hydrovac
Hyderabad
Hi all,
Is it ok to post this here... or should i post in wanted?
I am in need of these components, for my power amplifier project:
any leads to sources pl.
47V Zener Diode 5W (1N5368B)
15V Zener Diode 5watt (1N5352B)
1n5368b
1N5352B
Sachin
1n5368b
1N5352B
Sachin
I just saw they are out of stock.
Sachin
5 Watts Rating? Which Power Amp are you making?
200wpc DIY power amp.
1n5368b
1N5352B
Sachin
Thanks Sachin,
Gone thru already.
@hydrovac
Tried digikey india?
Raghu
Raghu,
Sachin said it all...
Element14 has them but you will need GST number.
1N5368B
1N5352B
Actually my requirement is 62volt Zener diode... earlier due to non availability of single diode, i had used these in series.
But, surprisingly found it here... thanks all for responding.
I hope you know that tanotis guys take order and then get them shipped from China and they usually take around a month to deliver to you without any proper communication regarding your order.
I am fully aware of the logistics Ramesh... but then, beggars can't be choosers :(... right?
Any reliable source in US?
What about rs components India? Some items have large purchase quantities unlike Mouser/Digikey though.
Krishna, maybe you could use Zeners of lower voltage/wattage in series to get
your desired value (though will take up more space).
For ex, use 6 x 9.1V 1W Zeners in series will give you 54V 6W effectively.
I bought these 62V single diodes... order is in process.
