I have faced this issue when l kept speaker more than actual in use and used echo mode auto. That is if you are using 5.1 and selected speaker as 9, then software can misbehave and turn of relay of center channel. l selected proper speaker set which was changed due to some reason and now center working perfect unlike used to shutdown in the middle of the movie. Now even with auto mode no issue for last month.I am having SR6012. Recently my center channel goes off on random days. When works at start it works through out. Anyone faced such issue?
Forgot to mention that l did this too when l used preout and one of front channels won't work. Not sure any ground issue with top cover or preout jack sensing issue. I didn't try preouts once all working fine .Few months ago I opened up the cabinet and dismantled all the PCBs, cleaned them and put them back together. It worked for a few days and then again stopped giving sound.
Ahh, I faced the same during the Audessy setup itself. Speaker configuration was setup right still there was no sound from center channel. I opened the case for any visual troubleshooting then after seeing the stack of boards on top of another I just closed it back. For few weeks I was running the center with pre-out, so was happy that processing path has no issues. Later as a try I switched the pre-outs with front and center to direct, viola it worked again.I have faced this issue when l kept speaker more than actual in use and used echo mode auto. That is if you are using 5.1 and selected speaker as 9, then software can misbehave and turn of relay of center channel. l selected proper speaker set which was changed due to some reason and now center working perfect unlike used to shutdown in the middle of the movie. Now even with auto mode no issue for last month.
Any update?I am having SR6012. Recently my center channel goes off on random days. When works at start it works through out. Anyone faced such issue?
I am not facing that issue anymore. Not done anything to fix. Only change I have done to AVR was ARC connection added from TV. so now everytime the AVR is switched ON it goes to TV Audio first.Any update?
Hi all, Thanks for your suggestion..placing order for the fans..takes fairly long to ship it seems...asking for customs details etc.. else may reach out to Joseph
Hi have given to Bhandup guy..he resolved the issue partly.. channels from conventional analog out is working but pre out which I used to to hook it up with my integrated amp still not working...some issue with the board....he is not getting it..Any update on the issue? Curious to know on the final resolution.
