hmm. The British units were better where you got inches instead of millimeters.I’m tempted with a ‘that’s what she….’ Joke.
Tried out this method in those videos. Got a near symmetrical positions. Did not quite get "follow my head" imaging. May be this method is not for horns? In that video I posted he says he was not quite getting this with his Klipsch. With a very acute toe-in with my Heresys I had experienced this but the stage was pretty limited.
That's the reason I had asked you why you have angled your high frequency driver downwards in an another postYes, I also questioned ....... is it more the spikes?? To find out :
You need to put all four spikes in place, to determine. If necessary, you may need to clean up the speaker's internal threads ( female ) , with a large tap, so you can easily adjust the threaded ( male ) spikes, as needed.
I would also LOVE to hear what you come up, angling the other speakers' ESL tops down, as we recently discussed. HAVE FUN. Trust what you hear, and double check.
Good luck in your explorations. Congratulations on trying and exploring, I love that you are doing that.
Jeff
I wish human ears were so sensitive as to discern 0.5% difference …![]()
Apparently we all instinctively crave symmetry…overcoming this for the sake of better sound in irregular shaped spaces might be a bigger challenge … visual aesthetic vs auditory aesthetic?This is wisdom, IMO. I've actually seen some people refusing to have slightly unequal/assymetrical placement because of various reasons while knowing that assymetrical placement produces symmetrical left-right balance. Another option is to listen slightly off center to balance out the left and right sounds. It can be jarring visually. Proof that we do listen with our eyes too![]()
I thought this illustrates the sentiment nicely (including the boat metaphor)All right ! Point taken …. I guess part of the fun is in attempting the tweaks in itself.
Whatever floats one’s boat.![]()
Oh Yes. My many 'ears ago my recliner used to vibrate with music and when i moved it out of the room the midrange cleared upI've have experienced changes as dramatic as with speaker positioning by moving furniture in the room.
Yes, definitely. I have bookshelves (the kind with books) at the first reflection points on both sides and immediately perceived a difference. The empty room was full of resonance (on clapping). Strategic placement of furniture, covering up glass surfaces with curtains and a floor carpet or rug helped tame these bouncing sounds to a great degree.The are a few other threads here on speaker positioning but i thought i would post this here as part of this active discussion:
Anyone else tried this?
And they act as very good ‘absorbers’ and ‘diffusers’ when room acoustics are disturbed by home minister.I normally get friends over to fill up the room and resolve issues with reflection and room modes.
Advantage is that they are easy to move and place.
Music sounds great when my living room is filled with friends.
