kmkaks
Hi All
I got a 55 inch Sony A80K Oled a few days back and am worried about the effect of power cuts on the automatic pixel refresh function.
I am from suburban Kerala, where power outages are a common feature, since KSEB regularly performs transformer maintenance and cuts tree heads that grow towards power lines. We also have rare instances of fluctuations causing low voltage when power consumption load is high, like on Festival evenings etc and regular lightning storms. We always make it a point to unplug all electrical equipment during storms though.
Just wanted to add that we have a single phase connection, if it is relevant, since I am an absolute noob when it comes to electricity. I do not expect to use the TV during storms or power cuts. Just don't want burn in or damage, so yeah, to my questions:
1) Is it ok to go for a line interactive modified sine wave UPS(The PC ones)? Will it deteriorate TV over long run? If yes what other option do I have?
2) Should I get a stabilizer? Or will the AVR feature in the UPS give reasonable protection?
If stabilizer is required, which brand and model do you recommend? It must work well with the UPS.
3) Also do recommend a surge protector, if needed. I am using the TV with a belkin 3 pin extension box which claims to protect against surges but I have no knowledge of this subject.
4) I plan to fix a luminous 2 kv inverter next year but that will only be to power lights/ fans/ necessities. How should I incorporate this into my current UPS purchase decision?
I was planning to buy this 1600v line interactive, modified sine wave ups:
www.microtekdirect.com
If there is any other option please suggest.
Going for higher VA one since it needs to power TV during entire course of running pixel refresher function I.e 20-30 minutes. Plus, might connect to game console in the future.
I wanted to be sure before investing since purse string is tight after installing Solar and buying TV. My budget for now is 10,000 rs
Cheers and Thanks a ton for helping out!I got a 55 inch Sony A80K Oled a few days back and am worried about the effect of power cuts on the automatic pixel refresh function.
Power Solutions Inverter UPS Battery
Microtek India is largest power product manufacturer offering Inverter UPS for home, Jumbo UPS Battery, Voltage Stabilizer, Wires and Cables, Solar Products, E-Rickshaw charger, Health Products.
