Multiple Sources To a Bookshelf speaker
krisna
India
Hi, i have an AVR and intg amp, is there a switch or router that i can use to toggle between the two connecting to my bookshelf.
Thanks,
Krishna Prasad
Hey,
You could try this.
Way over priced on Amazon but simpler to make one yourself though.
SOLUPEAK P2 2(1)-in-1(2)-Out Amp Amplifier Speaker Switcher Selector Switch Splitter 2-Way Loudspeaker Control Combiner Box https://amzn.eu/d/6iY488V
Just curious to know if these switchers affects the quality of signal when they connect to the Amp or Avr or result in any kind of noticeable delay.
Considering that the amp and speakers have numerous soldering points and junctions inside, and these looks to be simple passive junctions, I wouldnt think the difference would be quite negligible.
Thank you.
