Speakers for new tv
Gtk
Satara
Hi i want to buy speakers for my tv
My hall size is L shape with 13x32 and short side is 10x25.. My tv placed at long wall and distance from my tv is 10 feet
M on tight budget and dont know much abot avr amps and speaker matching..
My goal is to listen clear music and watch movies with surround effects..
Should i buy
yamaha yht 1840
Or Marantz pm6007 and floor standing speaker
Ot jbl 5.1 sound bar
Or sound bar with budget active sub which later i will use..
Plz help
Should i buy
yamaha yht 1840
Plz help
Just blindly pick up active speakers from edifier or Hivi as they are the best in your budget and sound like a million bucks, connect them to the tv or avr and there you have it. Not sure what avr you planned or already have as it's been many days since ur msg.
Should i buy
yamaha yht 1840
Plz help
Probably i think its better to mention your budget as well for better recommendation.
its an old post, update if you have already purchased
