What do you’ll use to clean inside of equipment?
prem
Hi members, the title I think is self explanatory. :)
Do you’ll use a soft brush or a cloth or a spray or a mini vacuum cleaner to clean the insides of an amp or a TV?
A vaccum cleaner with a mini brush head.
A blower (in a can) for the tricky parts - I know a lot of people will not be a fan of this but - a straw and blowing air works wonders too (no problem with moisture ever)
A natural hair brush for clearing off the really stuck gunk & then a fine sponge brush & cleaning alcohol as a last ditch.
I have used this combination on multiple devices, primarily, PCs & Some old amplifiers :)
Chander, are you suggesting the normal vacuum cleaner or the mini ones sold on Amazon for equipment?
Most mini vaccums will be fine; I have used those, please stay away from USB powered ones - the ones that come for car cleaning are more than enough.
Also if you have a regular vaccum cleaner - instead of the brush head, use a muslin cloth to cover the nozzle and then just run it gently over everything, a bit cumbersome, but works fantastic.
Either should be fine in my opinion. Battery operated one could be convenient but may or maynot have comparable suction power. :)
If you believe the marketing - you can check out DYson - not to start a VC war - but I have a set and it makes the job super easy :)
I have a rather different opinion.
Vacuum Cleaners are ineffective for this job.
For mildly dirty PCBs n insides I recommend a 1 inch width paint brush... Preferably one with stuff nylon bristles.
A strong blower (like the one used to clean Airconditioner grills) is ideal for really dirty insides.
Contrary to gut feel, the strong blower cleans best & does not damage any wiring (that has been my practical experience)
I second this option.
I use this
Indian Ears, I don’t see a big blower being allowed into the house :)
Anything that’s small and handy that you can recommend?
Few Vacuum Cleaner do have the functionality for blower - you may have to put the pipe on the exhaust/outlet of the blower instead of inlet .
I usually remove the filter inside to get some more power for blowing purpose, but , still does not come close to these blower.
like in Eureka F
like in Eureka F
Yes, but the blast is never as strong...
The one I have (Chinese, costs Rs 600) fits into its cardboard box 1 foot cube.
You are welcome to borrow from me 😉
Thanks for the offer.:) I would rather buy one and keep. Can you pl share a link?
I bought mine from Lohar Chawl.
Better deals there than on Amazon.
Mine is Chinese, No brand name but Model No 9027 ;)IMG_20230323_195034__01.jpg
Claimed specification is 2.3 cubic meters per minute
Incidentally, the box is just 9 inches cube !
Here is the best Prem, a water filter, nothing available, even remotely will compare :
Since 1936 !!! Patented.
