Bose Soundbar 900 with the sub vs Sennheiser Ambeo Max with a sub ?
sunster
Mumbai , India
What would be a better choice ?
Bose soundbar 900 with the acoustimass module 700 for 1,62,000 or
Sennheiser Ambeo Max soundbar for 1,65,000 which I will connect to my existing Boston Acoustics 12 inch sub.
Any users here for the above systems who can comment and recommend ? Usage is Atmos Movies and music.
Sunny
As per i heard Bose soundbar 900 , it was sounding balanced .
Sennheiser Ambeo Max is on brighter side little .
If you like brighter sound , then Sennheiser. Else Bose.
I think still u can use your existing Boston Acoustics 12 inch sub with BOSE soundbar as well. So u can save some money.
Why don't you consider AVR + 2.1 setup /at this price point. Anyday AVR + Speakers will sound better than Soundbars , and u can upgrade speakers to 7.1 and more in the future.
Sunny
I am in the same exact boat. Unable to decide. I also got Samsung q990b/c on my list.
MaSh
Sunny
Does the bose do Dolby atmos ? if so you wont go wrong with either.
Better to go with the soundbar with an integrated subwoofer ( Wireless) as is avoids cables.
Checkout the JBL Bar 1000/ 9.1 with detachable speakers for Atmos.
So I finally decided on the Sennheiser Ambeo. I could manage to get a home demo so I could connect the Soundbar to my Subwoofer and test it out. One word —Mindblowing. My better half came out of the room and asked if I had installed the entire home theater speakers again. It is so so convincing. The Atmos height effects and the overall sound signature is just fabulous. Very happy.
Oh where did you get it from?
MaSh
Great choice on Ambeo, as far as soundbars go, I believe it is ONE of the best out there (all this being subjective) & yes I have personally heard this.
If Ambeo allowed additional speakers to be mounted for surrounds & atmos, I will pick this up in a heartbeat!
Congratulations!
1,55,000 with the new offer price. It doesn't come with surrounds. None of the Sennheiser Ambeo series soundbars come with surrounds. But you dont need surrounds as the beam steering and the sound virtualization is so convincing.
Ohh thats a great then. Any idea if it's available for demo in Bangalore?
MaSh
No idea sorry. You can check with Sennheiser customer support. They will give yout the details.
Speak to Abhinav from Sennheiser Delhi. He could help you out. +91124-6627835
Hows the soundbar doing? Is the Subwoofer connection straight forward? Still dont feel the need of surrounds?
Do post some pics of your system.
MaSh
Sunny
After auditioning Polk/ Sonos/ Sony/ JBL Bose I found Bose 900 with 700 sub the best. Since the budget was 1.3 to 1.5 lakh I have to choose between Polk and Sony Bravia 8. Just want to know if anyone bought Bose at least 6 to 7 months back? How’s the performance and how does it handle software updates? Prob audio at Andheri Mumbai has quoted 90K for bar and 75K for Sub and 38K for surround against Bose store quote of 2.3 L. Polk Magnify Max AX is quoted 1.4 L by others and 1.20 L by Pro Audio.
I made following combination with quotation from Pro Audio Andheri West. Would like to know the best fit within 1.25 L.
Bose 900 plus sub 500
1.16
Sonos arc plus sub mini
1.07
Sonos arc plus sub mini app.
without brackets
1.5
Polk MagniFi max with sr2
1.2
Thank you
Go for bose perhaps it will fetch u better resale once you look for upgrade
It was finally between Bose Ultra with Sub 500 and Sonos Arc with submini and surrounds. Bose with 500 did not go well but Sonos with Sub mini and surrounds was astounding. Got this at Croma Malad
for 1.48 L. Delivery on 21.4.25.
