Hi All,
Like a lot of DIYers, RPI was the go to SBC for inexpensive Audio Streamer. With Allo BOSS , the audio quality (IMHO) was amazing for a fraction of the cost of other commercial streamers. The challenge with RPI and VOLUMIO now is that , RPI is hard to come by these days. Spotify has officially stopped supporting Spotify Connect and ShAirport is showing its age and some of my friends have had issues with newer IOS versions. I tried VOLUMIO on Intel NUC and was not 100% satisfied , then tried basic Ubuntu with MPD and YMPD for UI for NAS playback but this did not support streaming.
So I wanted a new solution with the following Features.
After considering many Android SBCs I settled on ODROID N2+ . It came in a 4GB variant and had good processing power in its class. The main SOC (Amlogic S922X) is a quad-core ARM Cortex-A73 and a dual core Cortex-A53 with a Mali-G52.
After getting the SBC , I got a wide screen LCD (WavShare 7.9inch Capacitive Touch Screen LCD, 400×1280) to give it a more of a streamer look.
I used Android 9 from Hard Kernel, there are third party versions for N2+ all the way to 13 and support for GApps.
Flashed the EMMC module with android and the board booted up without any issues. Touch worked out of the box and I reduced the font size, sideloaded VLC , Spotify and VNC Server and I was on my way, I have not installed GApps yet. I was able to use touch or an IPAD with VNC Client to control the device.
I then designed an enclosure and used laser cut 5mm acrylic to make it and here it is.
Running Spotify Premium.
Wanted to keep this post short, If anyone wants detailed build pics , DXF files for laser cutting etc, or have other questions please feel free to reply here.
- High Power SBC with good processing and RAM.
- Android Based (So I could use Spotify or any Streaming App that's out there for android even obscure ones.)
- Support USB DAC (I plan to use this as a Digital Source Only. Good USB Dacs do isolation , re-clocking etc. )
- Mature Android directly from the OEM, maintained by the OEM.
- Ability to play files from my NAS (Using VLC and use android apps like Poweramp Music Player)
- Control the device from a PC or IPAD.
