What might be the solution for my streaming upgrade?
cupholder9
Dunfermline
HNY to all, first time poster here and looking for some suggestions on how I might best to upgrade my system.
Here's some details of my current setup:
  • iPhone 14 Pro using Spotify (audio quality set to very high), so Bluetooth 5.3, using the Bluetooth to connec to:
  • Auris BluMe HD Long Range Bluetooth 5.0 Music Receiver Hi-Fi Wireless Audio Adapter with Audiophile DAC & aptX HD, using the Optical cable to connect to:
  • Marantz PM6006 which connects to:
  • B&W DM602 S2 (front speakers, one L one R)
  • B&W 607 S2 (anni edition) (rear spearkers, one L one R)
FYI - Marantz amp has loudness button active with the Bass knob with a negative quarter turn (Tremble knob left at default), I realise some might not agree with this but I like the warmer sound from the bass.
Also, I mainly listen to Progressive House/Techno.
I guess by top end idea/price would be switching out the Auris BluMe DAC for a Campbridge MXN10, which would cost £450, worthwhile, or any possible cheaper solutions?
Been waiting on Spotify Hi-Fi but TBH unsure if it would improve anything in my setup, what are your thoughts on this?
Thanks in advance.
Thanks in advance.
Or maybe the Marantz NR1200 since this would then stream rather that BT, correct?
Thanks in advance.
PM6006 has got 2 optical and one coax input. So you may consider adding either a WiiM mini through optical or WiiM Pro or ifi Zen streamer through coax to PM6006.
Thanks in advance.
Bought the wiimpro plus and it is good as a streamer.better than my allo boss2.Mine is the Marantz PM6007
Thanks in advance.
I have marantz pm 6005 and I am using wiim pro. Though I can use the DAC of my marantz , I am using the DAC of wiim . For streaming files stored on my mobile, it is a very good way. If you have spotify premium then you can access it through wiim home app else you have to select BT option in the app then you can listen to spotify (incase you don't have premium subscription.) Wiim pro can easily be a good upgrade to what you have these days.
