Can the Xbox One S (2017) play 4k remux off my HDD locally?
knackinblaze
India
I know that a similar thread has been posted here but in the other thread the op ended up buying the nvidia shield which I cannot due to its extremely high price, so high that the Apple TV is cheaper. I just want to confirm whether the Xbox One S (not the Series S) can play 4k media from local drive at native 4k resolution, as I saw a thread claiming that the One S only has native 4k support for streaming apps such as prime video, netflix or youtube, but plays at 1080p on apps like Kodi or VLC or Windows media player.
If no, I'd like someone to recommend something like the Nvidia shield just without the gaming stuff, or any other solution that can just let me plug and play 4k media from my HDD.
I am currently using a Shield TV doubling as plex server playing movies out a usb hdd.
This setup has its issues but gets the job done for the time being
The plan is to move to a dedicated media player like Zidoo in the future.
Thanks,
If streaming is not a requirement, then libreelec and coreelec work great. You can look up on their forums to see which devices are supported and what formats they can play.
Not true. I have X Box one x and it plays 4k movies through HDD cleanly && it supports Dolby atmos as well. With One 'S' model also it should do same thing , only difference is with One 'S' model you cannot download games offline since it does not have in built HDD. otherwise both One S and One X are same.
I am using Kodi player to play 4k movies from HDD, one more thing is when i stream 4k movies from my PC to KODI also it plays cleanly. Of course it depends on your Wifi router capacity as well.
If possible get Xbox Series S , if you are a gamer, otherwise just to play media Xbox one s is fine.
