DIY "Audiophile" Digital Coax cable
Amarendra
After DIY speaker, power and RCA cables, I thought of building my own digital coax cable. For this I sourced the cable from The Audio Co. Its a Furutech Cable (see snaps). Surprisingly the inner copper is not a single solid copper wire but a bunch of copper strands. Cable retails for INR 800/ metre.
For terminations I decided to try Aucharm solderless RCA plugs. These plugs were sourced from TheAudioCrafts @ INR 800 +150 per pair. See snaps.
This was supposed to be quite a simple exercise but I realized that the Aucharm plugs were slightly big for the wire. So i had to use some padding from the outer insulation to pack it.
Listening tests/conclusion:
The Aucharm RCA has a very strange construction. Besides being too large, the outer blue casing / covering is too close to the actual end terminal. The result is that it can't go into the coax out of the WiiM media player where the Coax Out is slightly recessed into the box of the media player. So I had to remove the blue cover from that terminal.
This Furutech cable replaced a free SPDIF cable. So the switch was not only from SPDIF to Coax but also from a free unbranded cable to a branded cable.
I found a slight difference in sound. Thinking that I was biased, I played a few songs for my daughter who mentioned that some instruments which were usually not noticed earlier (too soft earlier?) could be heard and it felt like the singer was taking more time to sing (more space perhaps ?) :)
If you have suggestions for solderless RCA plugs please share.
Thanks for reading. As always suggestions welcome.
Has anyone tried this and can it distort the signal ?
To answer your questions ... and provide an explanation:
1. Yes, I have tried these connectors. They are Not meant for use at High Frequencies (eg the type used for SPDIF signals)
These connecters are Complete "Phoo-Phoo" for SPDIF and Digital Clock Signals
2. Yes, they WILL Distort the SPDIF signal. (More on that later)
3. A Basic brief on Cable Impedance.
A CoAxial cable (the type used in a Digital Coax cable) is as shown in this pic by you, Amarendra
The Impedance of tis cable depends on:
1. The Material of the dielectric... which is the white plastic between the Centre Copper wire & the outer copper braiding ("jali")
2. The material & Diameter of the conductors
3. The diameter of the dielectric i.e. (constant) distance separating the Centre Wire & the Braiding. Note that the Braid Completely Envelopes the centre conductor
To maintain its 75 Ohm Impedance, the distance separating the Centre Wire & the Braiding MUST REMAIN CONSTANT THROUGHOUT THE CABLE + CONNECTOR ASSEMBLY.
The green & black connectors do not maintain
a. The Constant Distance
b. The outer braid does not completely cover / envelope the centre conductor. It runs alongside :eek:, where the 2 screws are located!
Hence 75 Ohm impedance is thrown out of the window, for any Coaxial cable using these connectors.:rolleyes:
Since the impedance is not maintained at the required 75 Ohms impedance, the Signal Will Be Distorted.
This distortion will not be dramatic, particularly on a less revealing (usually budget priced) system.
The Million Dollar questions:
x. Is the distortion audible?
y. Is the distortion euphonic? Do you actually prefer the euphonic sound?
Both the above: x & y are upto you and your system.
I would urge you to even try any analog interconnects for SPDIF signals, and even Cheap RCA to RCA Cables that are typically bundled free with DVD Player.
They will all work and provide a different sonic signature. If you like it ...... you can use them. They will not damage your Audio Components.
Sadly, "Cable Impedance" & "System Impedance" is rarely well understood (Even though it can be explained quite simply), and lots of misconceptions prevail.
There has already been a relevant discussion on this topic here on this very forum, in 2021. Do check it out.
I have 2 pairs of hifidelity HT-CR1 RCA cables and one coaxial digital. They all look exactly the same. So when I got the coaxial, I wrapped a rubber band around it and kept it in my cables box.
One day my daughter needed a rubber band to tie up her barbie's hair, and took this rubber band. It's been 3 years, and trying to separate that coaxial from the RCA's has become the obsession of my life.
Thanks !! I have ordered the cheap connectors and will experiment over the weekend.
From what I understand these cheap connectors should be more palatable in an analog RCA cable - such as the one between DAC and amplifier ?
take care while terminating Balun connectors, you can easily end up with a short. Heat shrink each core (even so if core and shield).
Ideally, they should be used for low voltage power, such as 5 Volts or 12 Volts from a wall wart.
Yes, such RCAs can also be used as compromised connectors for non demanding audio use
What is the compromised part in these connectors ? You explained for digital connection but what’s the compromise in analog signals ?
In a single word .... "shielding'
The woven braid and / or foil tape no longer envelopes the inner conductor of the cable.
That probably also holds true for the signal path inside the RCA connector with side-by-side screw terminals.
