New member
tlaidlaw
USA
Hi, Thanks for allowing me to join. I look forward to learning and eventually being able to share what I learn.
Welcome to HFV.
If the post / response to you helps in any way, use the 'Like' button which is located at the right hand bottom of the post. This helps to build up positive reputation for the FM (Fellow Member).
Hope you have a great journey here!
All the best!
