Help to choose between DENON AVR-x580bt & DENON AVR-S660H
DR MUDHAN
Chennai
Dear All , planning to buy DENON AVR. Kindly guide me which one is better X580BT or S660H.
Pricewise not much difference. Thanks.
I’d check out the Onkyo SR-3100 - should be similar price, much more power, calibration, Dolby Atmos, which these two Denons don’t have
Thanks for your kind response. Is ONKYO SR-3100 available? Can you suggest some seller in Chennai or Bangalore?
Would suggest you contact Anil (HifiMart), he will offer a good deal where possible once you finalise the AVR or he also could possibly suggest another good AVR which may suit your requirements.
I am thinking of Denon AVR-S660H since its impedance level goes down till 4 ohms while the others only till 6, since i am going for a speaker which low level is 4 ohms so it make sense i have a avr that matches. worth looking into.
