Best passive bookshelf pair under 20k
GDSAlpha
Delhi
Hi friends, recently bought a Fosi V3, looking for recommendations for a pair of passive bookshelves under 20k(25k max)
Preferences- decent bass and mids
Source- Bluesound node 2i
Genres- Rock, indian classical
Room size- Small to medium
Both new/used options are ok.
Thanks in advance!
In this budget you can look at some Indian options like sound king, Norge etc. OR used stuff from some reliable seller. There are some options on Hifimart (Mission, Fyne audio etc). Just match the specs carefully with your amp before making any purchase specific to wattage and ohms.
Don't go anything below 8 inch drivers.
Hunt your local electronics for Good brand fullrangers or Woofer/tweeter setup. Fix it into bigger box(subwoofer box) .Dainty, Award, Sweton are good. We are not getting Boston/Philips these days.
Within his budget limits?
