Speaker Upgrade…..
ishmeet73
Pune
I bought the SVS Ultra Towers as a replacement for my old DefTechs 7006 to pair my Parasound 2100 + 2125 ( Pre & Power Amplifier).....
However, I just got bit by the unsatisfied bug. I finally ended up changing my whole system. Now my system consists of the following,
Eversolo DMP-A6 (ME) --> Denafrips Hermes --> Denafrips Pontus II --> Luxman L505 uxII
Now I am looking to change my speakers, would love some help in this regard. My budget is around 10 Lacs.
I like to listen to a lot of vocal, Jazz and Western Classical Music. So a great mid-range is really important.
Any and all suggestions would be highly appreciated.
For the Music you described, do demo some BBC style speakers. Since you are in Pune, Spendor should be on demo locally. Check out their Classic line.
Adding to what jai mentioned proac response k1, proac d48r, SF Olympica nova II, Joseph audio pulsar graphene should be on your demo list since your focus is more on midrange
I am sorry I should have mentioned this in my original post, I am looking for Floor Standing Speakers.
You may get better recommendations if you indicate your room dimensions too.
10 lakhs is a serious budget and it’s worthwhile doing several auditions of different options available locally at showrooms in Pune and Bombay.
If you can listen to some good set ups at FM in Pune that could enrich the selection experience.
In addition to suggestions from @Phew , Tower speaker brands Worth considering for rich mids and vocals are:
Fyne audio
Totem
Zu audio
Tannoy
Altecs and JBL
Some home work research on specific models would be required
I am sure others will chip in with specific suggestions
Kef and b&w has bit me hard and anything outside these seems like a compromise.
Fyne audio
Totem
Zu audio
Tannoy
Altecs and JBL
Thank you for the suggestion regarding the room dimensions. I have a dedicated music room cum den, measuring 16’ x 12’.
The KEF I am in love with are the Reference 3 Meta, alas they are a tad out of my budget. I am hoping and praying to find a good used pair.
Sorry not a great fan of B&W. That said I haven’t had the opportunity to hear the 7 Series or the 8 Series.
you can get a reference 1 meta and dual REL subs and it would be on par with the reference 3 meta.
Alternatively the q Acoustics concept 300 with rel subs would be also a great system. If you want coax, mofi source point 8 would also cut it
Thank you all for your suggestions.
Thank you for your suggestion, I didn't go with the KEFs. But I did take your suggestion about going with Stand Mounted speakers instead of Floor Standing Speakers. I intend to go with Dual Subs once the speakers have opened up and I have gotten used to the sound.
make sure you are high passing the mains so that they will go loud without any distortion. I think if you high passing the mains them at 60hz or 70hz it would be great
Sub woofers, I am planing REL. I am leaning towards a pair rather than a single sub. But not before April / May 2025. And yes, I plan to use the high pass route.
Will give a feedback once done.
