Wharfedale DIY KIT
HiFiVision
Super Moderator
Wharfedale DIY KIT
Limited to just 500 kits worldwide!
Fifty years after inspiring a generation of DIY enthusiasts, Wharfedale proudly presents a limited edition release of two brand-new kits. These kits not only celebrate our brand's rich history but also honour the revival of the DIY movement, following the legacy of the Wharfedale Heritage Series. Each kit—available in both 2-way and 3-way configurations—is limited to just 500 units.
Inside each kit, you'll find everything needed to build your own high-performance speakers: fully assembled crossovers, low-frequency drivers, midrange drivers (included in the 3-way kit), and meticulously matched high-frequency drivers. Each component is crafted to the exacting standards that Wharfedale is renowned for, with specifications and tuning overseen by Peter Comeau. The kit also includes terminal panels, connecting cables, full-size cutting templates, and detailed instructions—just like the kits of a half-century ago.
Presented in a luxurious gift box, these kits are not only collector’s items but also the perfect project for hobbyists. The Wharfedale 2-way and 3-way kits offer an exciting opportunity to create a masterpiece that you can take pride in.
Wharfedale DIY KIT Key Features:
50 Years in the Making
A luxurious reimagining of the classic Wharfedale DIY kit, honoring half a century of innovation.
Your Way: 2-Way or 3-Way
Choose between a 2-way kit featuring a 6.5” woven Kevlar low-frequency driver and a 1” soft dome high-frequency driver, or a 3-way kit with an 8” woven Kevlar low-frequency driver, a 5” woven Kevlar midrange driver, and a perfectly matched 1” soft dome high-frequency driver.
Everything You Need in One Box
Each kit includes the respective speaker drivers, a crossover, cables, terminals, port tubes, and all necessary fixings.
Expertly Guided
Comprehensive instructions, cutting templates, and expert guidance are provided under the direction of Wharfedale’s Acoustic Director, Peter Comeau.
Limited Edition
Presented in a luxurious gift box, these 2-way and 3-way kits are limited to just 500 pieces.
Wharfedale 2-Way DIY KIT Specifications:
Model:
2-Way Kit Speaker
General Description: 2-way vented-box/standmount
Enclosure Type: Bass Reflex
Transducer Complement: 2-way
Bass Driver: 6.5" (150mm) Black Woven Kevlar Cone
Treble Driver: 1" (25mm) Soft Dome
AV Shield: No
Sensitivity (2.0V @ 1m): 87dB
Recommended Amplifier Power: 20-120W
Peak SPL: 95dB
Nominal Impedance:
Cabinet Reference Volume: 14L
Cabinet Reference Max Dimensions:
  • Height: 340mm
  • Width: 240mm
  • Depth (including terminals): 264mm
Packaging Kit Box Size: 570 x 420 x 120mm
Net Weight: 4.8kg/set
Gross Weight: 5.8kg/ctn
Wharfedale 3-Way DIY KIT Specifications:
Model:
3-Way Kit Speaker
General Description: 3-way vented-box/standmount
Transducer Configuration: 3-way
Bass Driver: 8" (200mm) Black Woven Kevlar Cone
Midrange Driver: 5" (135mm) Black Woven Kevlar Cone
AV Shield: Not Included
Sensitivity (2.0V @ 1m): 88dB
Recommended Amplifier Power: 25-200W
Peak SPL: 110dB
Nominal Impedance:
Cabinet Reference Volume: 4.8L & 33.6L
Cabinet Reference Maximum Dimensions:
  • Height (with plinth): 565mm
  • Width: 300mm
  • Depth (including terminals): 318mm
Packaging Kit Box Size: 710 x 510 x 160mm
Net Weight: 10.5kg/set
Gross Weight: 11.8kg/ctn
Exciting News! 🚨
The highly anticipated Wharfedale DIY Kits are coming soon to HiFiMART.com! 🎉
Whether you're a seasoned audio enthusiast or just starting your DIY journey, these limited edition kits are your chance to build your very own high-performance speakers. With meticulous craftsmanship, premium components, and expert guidance, the 2-way and 3-way kits are set to deliver an unparalleled audio experience.
These kits are limited to just 500 units worldwide, and they’re expected to sell out fast! Don’t miss your opportunity to create something truly special.
