Murthy's Cables ( tools & trades ) bangalore
How good when we compare them to belden speaker cables?
Never compared to a Belden. It was comparable in performance to Mogami 3103/4 cables. Different presentation though (Mogami is warmer, generally more refined)
I have asked him about speaker. He said its 600 per meter with out connectors
I had bought mine used so cant say about cost. Had spoken to him about adding connectors and he recommended against it. He applies tinned solder at the end and recommends that over banana / spade connectors.
Yes. He also told me to go with out connectors
I have been using Murthy's 2 pairs of RCA interconnects for the last 1.5 year and am very satisfied with the cable. The little problem I am facing is that the cable is not that flexible, so it needs more room on the back,when I connect to AV equipments.
Are you connected to your power amp. And its price. As Iam also looking for good rca interconnect to connect my Pa. Which I will receive by next month from o&b. And I havd shortlisted mogami.
Murphy's cable is very nice. I have chosen a 1 meter cable with a medium-range connector. I have 2 pairs, so it cost around 6,000 rupees something, but I don't remember the exact amount that I paid.
I don't know much about the mogami interconnects; they will be great too. I am using mogmai speaker cables at the moment but will soon be replaced by occ cables.
I have connected simple rca cable from amazon and also other brands from PRE to Power , could not find any difference, though DAC to Preamp, I am using good quality RCA cable.
Before Murphy's cable, I was using a very simple RCA that cost 100-200 rs at that time. It was great for me. But when I switched to Murthy's cable, I felt a lot of difference in my system. base and highs are more precise; feel more weight in the base, and also more dynamic. cheap RCA highs and base is very thinner in my case.
i am not saying Murthy's cable will be the best. Good-quality cables will make this difference. But too expensive cables are just fake promises too.
Currently I have connected SKW RCA cable b/w pre and power, though this cable is very stiff and hard to bend at places ,but the fit and feel seems to be durable.
And Mogami between Dac and Pre.
Mogami or Dhivis which is best tk connect
Preouts of avr to power amp
I have no experience with Dhivis. But they have good cables a lot of fms are using, i guess, and they are also budget friendly compared to mogami. Mogami interconnects will be double the price of dhivis. maybe dhivis users can comment here to know more about it . i am also intrested to know it for a project.
