Good Bluetooth receiver for converting wired headphones to wireless
vidh2024
Chennai
Pls suggest a good Bluetooth receiver for converting wired headphones/earphones to wireless in the price range of 1000rs
I am using one by musesonic (trans receiver) but the price range is little higher say around 1800. It works well. Basically I use closed back on ear type normal headphones (sony) having impedance of 28 ohms. You get all these stuff made in china be it muse sonic or any other brand in budget range and the quality is just OK nothing exceptional, solves the purpose. I connect blue tooth device to MI box and then use the headphones for audio of TV programmes. I can also take audio out to any other device like non blue tooth amplifiers. The other brand I can think of is Cubetek.
Thank you 🙂
Order placed for musesonic receiver. I think there are 2 products of this brand.. One is a receiver only at 1120rs and the other is both transmitter and receiver at 1880rs.,So i ordered the bluetooth receiver.Thanks so much for the suggestion.
The other product I found was tp link receiver with excellent reviews but no inbuilt battery.. Always should be connected to usb.. Since I am buying mainly for headphone, inbuilt battery is must, so ruled out tp link
Great. I am glad my inputs turned out to be fruitful for u. But as I said in my previous reply do not expect high audiophile grade performance from such device. It will be decent enough for normal headphones as well as home system.
