Power Amplifier
Manoj Nair
I happened to get a Schiit Saga 2 preamplifier from a friend of mine who came in from the USA.
Could somebody suggest me a small Power amplifier for the same which could run a small satellite speaker connected to the Laptop.
Also Budget is an issue .
Thanks for all your help and advice .
Manoj
PS Schiit PreAmp photo attached
Like Manohar mentioned I highly recommend Fosi audio :) I had v3 fidelity is ridiculous for the price
you may want to go through this thread (small footprint and budget friendly amps)
Manoj
Finally I discarded my plan to connect it with a small Power amplifier and went ahead and connected the same with the existing Pulz HA 400 power amplifier.It is connected to the Schiit Loki+ tone controls along with the Yamaha WXC 50 streamer .
Speakers are 10 inch Vintage Pandam of the mid 1980s.
Performance is good and satisfactory .
Photograph attached for information .
Thanks to all HFV members for their advice and support .
Manoj
