Jamo E570 only tweeter is working
Samson kumar
Hyderabad India
Hello need help or fixes on why the midrange and woofer is not working on the right tower. Only the tweeter works. I opened the speaker plate and checked no loose wires but sometimes when I shake the tower all speakers work for a while. The speaker is connected to a denon pma655r through a Marantz eq580 equaliser. 5he left tower is working well.
Hello an update I interchanged the speakers look like an issue with the amp or RCA cables!
It is usually the rca cables or dry solder joint on the inside of the amp where the cables are plugged in just a simple touch with a very small amount of solder with a soldering iron will fix this issue for many years!
